Lighting HID/Xenon kits, Retrofits and Associated Topics
HID Auto Levelling Not Working
Old Sep 20, 2016 | 07:03 AM
Snakecharmer's Avatar
Default HID Auto Levelling Not Working
Hi all, I hope someone can help me please. Honda S2000 (2000)
I recently got caught out in the dark with my headlights pointing very low to the ground. It seems my auto leveler was not working. On turning the ignition the lights would
come on, move up and down and then go out at startup. On checking the sender unit at the rear left wishbone I found the actuating arm to be bent. I suspect I may have
hit some debry on the road.I stripped the unit down,straightened the adjusting actuating arm and checked the electrical contact at the plug. Also the sender unit which
seemed to rotate smoothly and was without any damage. Still nothing working. Both lights work fine and I have reset the heights manually so that it is derivable in the dark.
Having picked up some info from a Civic forum I made some voltage and continuity tests at the plug connector to the sender unit and got no readings for either voltage or continuity
and think the problem may lie with the control box. Can someone please tell me if the auto leveling is done via the main relay control box or would it be a separate unit altogether?
In anticipation, Chris
Old Sep 22, 2016 | 06:50 AM
tony_2018's Avatar
Fish Twig
Default Re: HID Auto Levelling Not Working
Might want to check power to them, any fuses and what not.
krcm0209
Sep 28, 2018 09:27 AM
Apolloautolight
Aug 25, 2016 02:29 PM
danzig2010
Honda Civic (2006 - 2015)
Aug 3, 2016 05:58 AM
camokatu
Honda CR-V & Element
May 3, 2011 06:36 AM
Ensignhiro
Jul 19, 2009 09:38 PM
