Having a real hard time deciding!
I have an 08 Pilot and want to put a HID kit on. The bulb is an H11 55w. I cant decide if I want a 4300k or 6000k. I know 4300k is like OEM and 6000k has almost a slight blue tint to it. Would I have to get a 55w kit being the H11 is 55w or could i do the 35w? Should I get 4300k or 6000k? I cant make up my mind. Any help and experience with any of these kits would be greatly appreciated.
To Start, all OEM HID's are built as 35w systems for a reason.
Life span, proper Light output and electrical Efficiency. 55w HID system produce very high temperatures 700+deg F, in our Testing 55w ballast draws more amperage than your vehicles wiring is rated for. We Use 55w-150w ballast in off-road use only.
I ended up getting a 4300k hid kit that is 55w. Is that going to be to bright and blinding? Its for a Honda Pilot taht uses a h11 55w bulb.
if no fuses blow, its fine.
DO NOT replace the blown fuse with a larger one!
if you do, you risk melted harnesses, and electrical fires ^^
it should be fine, '08 pilots have decent halogen projectors, you might just need to realign the cut off..
search google or ht for how to align your headlights.
Its not the Watts that you have to worry about its the Amps that the system draws.
55w HID systems
Inrush current : 8A~12A
Steady current : 5.5A~6.5A
Modified by DrivenMC at 12:51 PM 6/1/2008
55w HID systems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STICKIELEGS »</TD></TR><TR><TD CLASS="quote">DUDE GET THE 8K THOSE LOOK GREAT I GOT THEM IN MY WIFES PILOT...
35w or 55w?
</TD></TR></TABLE>35w or 55w?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivenMC »</TD></TR><TR><TD CLASS="quote">12 AWG Is rated to transfer 9.3 Amps
This is the Formula to find out what AWG you have.
D(AWG)=.005·92((36-AWG)/39) inch.</TD></TR></TABLE>
Furthermore, all our wiring for the headlights use 18ga.
The higher in number the wires are, the thinner they are. That's why when installing an amp setup, they often use 0awg(american wire gauge) because it is thick. Thick means it can handle more.
usually aftermarket hid kits comes with relays or optional.
just pay the extra for peace of mind unless you got a fire extinguisher handy.
I finally did get a 8000k 35 w system with a relay, but i might be taking it out soon,( Warranty purposes) and I have noticed the light out put isnt the same(useable light) I find my self having to use the brights a lot on back roads.
