Lighting HID/Xenon kits, Retrofits and Associated Topics
Ef Civic Wiring Issue
Old Mar 15, 2024 | 07:27 PM
kezza94's Avatar
Default Ef Civic Wiring Issue
I'm having a bit of a weird problem with my Ef Civic.
So previously my Park Lights were all working fine, got a hand from someone yesterday to test that my brake lights, indicators and park lights were all working before I started putting the plastic trims back in the boot and my brake lights work, indicators work but when lights are turned on Park Lights don't come on in front or rear.
Yesterday I had removed the Rear Window Wiper motor so I could install Centre Garnish, reinstalled everything and tested the Rear Wiper today to make sure it worked and it did, but now whenever I turn ignition to 'ON' position 1 park light bulb comes on in Rear.
I replaced the Front/Rear Park Light bulbs, checked the grounds, checked the fuses, cleaned up the corrosion in the Tail Light Sockets, tried another Indicator Stalk just incase and still same problem.
I've spent time searching Honda Forums with no luck with a answer.
I'm really hoping someone has experienced this issue before and is able to shed some light and/or things to try.
devious
Aug 5, 2020 03:45 PM
Greyhead
Honda CR-V & Element
Jan 30, 2014 07:42 AM
VI Boost
Lighting
Feb 25, 2011 09:02 PM
Dat1BVtecN
Nov 14, 2007 08:43 PM
