Dome light led conversion help
Hi all,
Ok, Well there was a super good deal today at a local store for "stick and click LED lights". This got me thinking becuase i always wanted to change the lights in my map and dome light in my car to a nice bright white light for quite some time now. Lets just say i stocked up on them heh.
Anyways i took a few of the lights apart and heres what i found. Each one has its own pcb with 3leds on it and a 10ohm resistor all wired parallel. All controled by 3AAA batterys. 4.5volts
So its in this order for the connection on the pcb: (+)positve ---> 10ohm ---> switch ---> 3 led parallel ---> (-)negitve
Now my questions is: How do i wire this up to my dome and map lights in my car that draws about 12v-14.4v I have it planed out so far or how many leds will be in each. For the dome im going to have 5 x 3led (total 15leds) and the map will have 2 x 3led (total of 6leds)
If you need any more information please let me know
I'm not an EE, nor do I have an EE Degree..
I think you will find more help at HID Planet's LED Forum.
imo, sounds like a bigger hassle than actually just buying leds, and making your own board or using a breadboard...
or even just buying some plug in ones off of ebay: http://www.v-leds.com/
To better help, i thought ill'd take a picture of front and back of the pcb.
Let me know if i should replace the 10ohm with the 120ohm or should i just rewire the whole thing. If so were would i find pcb
bepperb
Nov 3, 2010 07:18 AM
I_SI_u_behind_me
Honda Civic (2006 - 2015)
Feb 11, 2008 06:44 PM
