Lighting HID/Xenon kits, Retrofits and Associated Topics
corner lights messed up
Old May 10, 2009 | 06:11 PM
CPreston's Avatar
Default corner lights messed up
on my teg, the right corner light doesnt light up when my lights are on but its not the bulb becasue it works when the turn signal is on.
what could be the problem.
Old May 13, 2009 | 03:37 PM
CPreston's Avatar
Default Re: corner lights messed up
nobody?
Old May 13, 2009 | 04:26 PM
TunerN00b's Avatar
Just because the 27W blinker filament is still intact and lights doesn't tell you anything about the 5W parking lamp filament.
Check the bulb, which is probably the issue.
Old May 14, 2009 | 06:11 PM
CPreston's Avatar
so youre saying a bulb that lights when the turn signal is on but doesnt light up when my lights are on could just be a bad bulb?
Old May 14, 2009 | 06:19 PM
98civdx's Avatar
Master Detailer
it is the light bulb my civic had same problem new light problem fixed.
thoses lights are dual fillimate one can go out and still have the other one working.
Old May 14, 2009 | 06:21 PM
TunerN00b's Avatar
Yes, just because 1 filament has failed doesn't mean the other has too. Visually check the bulb.
Thats how it produces 2 different light outputs. Running lights are dim, turn signals and brake lights are brighter. Sounds like you just lost the dim filament.
Besides, bulbs are what, $2? Just replace it and see if its fixed. If not, eh, it was only $2, and you can continue troubleshooting from there.
Old May 14, 2009 | 06:33 PM
CPreston's Avatar
ok, ill take a look at it. how do you take the corner light out? ive tried and cant get it.
Old May 15, 2009 | 11:08 AM
TunerN00b's Avatar
You don't state what year teg you have. If its a G3, remove the single phillips screw visible on the outside. If its in the rear you don't remove the lens, you access the bulb from inside the trunk.
Old May 21, 2009 | 11:35 AM
Teg LS's Avatar
http://www.team-integra.net/sections...?ArticleID=713
shows how to take out front corners if thats what you need to replace the bulb
rawrjaay
Aug 24, 2022 02:38 PM
invader_zim
Mar 28, 2012 09:57 PM
LShatchie
26
Jun 29, 2005 03:21 AM
Edgemingsr
Aug 18, 2004 11:45 AM
