Lighting HID/Xenon kits, Retrofits and Associated Topics
anyone know how to wire side fogs???? (dc2) cornering/intersection lights
Old Jul 7, 2008 | 08:35 PM
energ3tic2's Avatar
Default anyone know how to wire side fogs???? (dc2) cornering/intersection lights
ok i believe the correct way to wire the lights is so that the light for that side is only on when you signal.....i plan to run a relay for each side...i just can't figure out where to tap into 12v for the control to my relay...any help would be great...thanks
Old Jul 10, 2008 | 07:25 PM
pimpwagon's Avatar
Default Re: anyone know how to wire side fogs???? (dc2) cornering/intersection lights (energ3tic2)
you should have 2 flashers in the fusebox dedicated to left and right side blinking. if you tap into these before the flasher and not after youd have the proper signal to run your relays. if you did it after the flasher, it would blink like the signals.
Old Jul 11, 2008 | 05:18 PM
energ3tic2's Avatar
yea thats what I was trying to do but there arent any wires before flashers ... that part of the circuit is integrated into the dash fuse box...
JDMarshal
Lighting
Aug 3, 2010 03:44 PM
energ3tic2
Jul 10, 2008 04:50 PM
Francesco
Honda S2000
13
May 31, 2006 03:16 PM
EJ8 GSR-T
Sep 16, 2004 07:31 PM
