Lighting HID/Xenon kits, Retrofits and Associated Topics
97 Accord Headlight bulb replacement
Old Jul 6, 2023 | 08:55 AM
GasGas05's Avatar
5 Year Member
Default 97 Accord Headlight bulb replacement
This is weird to say the least. Trying to replace the low beam headlamps in a 97 Accord V6. Sylvania parts indicate the 9006 in the Silverstar series. The drivers side bulb will not fit. Tried for one hour. I checked the measurements from the older Stanley HB3 vs the Sylvania and there is a 1/8” difference in the barrel diameter which will not insert into the headlight housing. Does anyone know what bulbs will correctly fit? This is crazy and the bulb manufacturers do not list measurements.
Old Jul 6, 2023 | 10:07 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 97 Accord Headlight bulb replacement
The OEM bulb for the low beam suppose to be a HB4 bulb (9006 equivalent).
If the bulb you pulled out as a HB3 bulb, that is equivalent to a 9005 bulb. Was the headlight assembly replaced before? If so, it could be an aftermarket that did not directly match OEM assembly.
Old Jul 6, 2023 | 10:44 AM
GasGas05's Avatar
5 Year Member
Both Headlight assemblies are Stanley 001-6677. I’m thinking
it’s just Sylvania but 1/8” to 3/32nd difference in the base diameter is substantial between the two different bulbs and the housing.
fedorafugu
Jan 20, 2016 07:58 PM
beeman65
Feb 26, 2007 02:01 PM
thatasiankidtony
Feb 5, 2007 07:37 AM
b16ferio
Aug 31, 2005 07:08 AM
robbo
Aug 13, 2003 11:28 AM
