Lighting HID/Xenon kits, Retrofits and Associated Topics
4300k vs 6000k?
Old Dec 28, 2007 | 01:56 PM
  #26
Imp-tuner's Avatar
From: Santa Ana ES in 415 NORCAL where clean ricers are found :P
Default Re: (prelude1897)
But the cars that have lower than 6000k and no retrofit....are the ones who really blind people 'cause is damn white.....
Old Dec 28, 2007 | 02:40 PM
  #27
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Imp-tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Imp-tuner &raquo;</TD></TR><TR><TD CLASS="quote">But the cars that have lower than 6000k and no retrofit....are the ones who really blind people 'cause is damn white.....</TD></TR></TABLE>
No.
Blue light is much more harsh on the eyes than white or yellow. So even though there are less lumens coming from 6000K or higher than from a 4300K, it's still going to look like more glare and be more painful to see them coming toward you.
Old Dec 28, 2007 | 05:08 PM
  #28
MTK Kommander's Avatar
Default Re: (PatrickGSR94)
sorry i left you alone in this thread patrick! haha.. man i used to love these discussions of ricer 6000K vs. good HID.. people arent blinding you because of the color of their light, its because they are buying HID kits with no glare protection..
remove your bulbs from your civic, and u will notice the low beam filament inside the H4 bulb has a little shield under it to block any light from hitting the lower half of the reflector which would cause light to go upward into peoples eyes.. now if you go on ebay and piece together a kit the right way, you will have a nice looking kit, without having to get that shitty 6000K to make it look like "the stock blue look"
on my gf's 01 civic, i went on ebay and got H4 adapter shields, similar to the caspers ones of a few years ago.. these ebay ones are much better though, not to mention $25 for a set, rather than $50 for a set.. plus the ebay ones have a notch inside to keep the bulb from spinning when you try to lock the ignitor.. so i bought those for $30 shipped.. usually a set of brand new philips D2S bulbs go for roughly $85 on ebay.. then you can find a set of ballasts anywhere from $150 to $280..
with that setup, you will have perfect glare protection.. you can actually see a cutoff on the wall..
patrick, go on ebay and buy new bulbs..trust me.. if yours are 4 years old now, you will be BLOWN AWAY at the difference new bulbs make.. i changed my stock 2001 osram bulbs to some brand new philips on the m3, and WOW.. i couldnt believe it.. i will probably start changing my HID bulbs every couple years..
Old Dec 28, 2007 | 05:49 PM
  #29
HAPRECYCLING's Avatar
I got an aftermarket kit High beam and low beam. No retrofit and I dont blind anyone. I have even tested myself. Had my friend drive my car towards me while I drove another car. I got 6k. I do have 2 shields? this may be why? a stock shield in my headlamp and there is a shield on the aftermarket HID bulb. Im using aftermarket high beam, low beam bulbs w/ factory Acura TL Igniters and Ballast. I like it alot and get lots of complimants on it. I personaly dont like the retro fit deal, using s2000 projectors in a stock lamp. Looks kinda Ricey to me. I like my factory headlamp look. No projector. Thats just my opinion. Opininons are like a$$ holes we have one.
Old Dec 28, 2007 | 05:54 PM
  #30
wanahonda's Avatar
my 6000k's were a lot more blue at first, but once they burn in (After 100hrs) theyre more white, not ricey in the projectors
Old Dec 28, 2007 | 09:10 PM
  #31
jewpont's Avatar
does anyone have pics of their non projected 4300k or 6000k HIDs?
Old Dec 29, 2007 | 05:11 AM
  #32
Community Builder
Default Re: (MTK Kommander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MTK Kommander &raquo;</TD></TR><TR><TD CLASS="quote">
so wait, you used OEM D2 bulbs in a Civic? How did you get that to work?
oh well, I'm still a PnP HID hater
Old Dec 30, 2007 | 06:40 PM
  #33
Thats my set up. I need to adjust the passanger side now that I look at it. I have never looked into the retro fit before. But now that I have done some investigating the cutt off line looks really clean w/ the projector! Thinking maybe I might get some projectors from work and reto mine too.
Old Dec 30, 2007 | 10:03 PM
  #34
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
oh well, I'm still a PnP HID hater </TD></TR></TABLE>
with H4 adapter shields.. adapts D2S bulbs to an H4 housing with a glare shield
Old Dec 31, 2007 | 10:49 AM
  #35
y7turbo's Avatar
with H4 adapter shields.. adapts D2S bulbs to an H4 housing with a glare shield</TD></TR></TABLE>
thats what i just picked up
matsushita gen3 ballasts, phillips d2s bulbs and the new version of the caper shields.
ill see how it is. if the glare is real bad, ill just pull it out and buy some projectors.
Old Dec 31, 2007 | 01:11 PM
  #36
Default Re: (y7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y7turbo &raquo;</TD></TR><TR><TD CLASS="quote">
ill see how it is. if the glare is real bad, ill just pull it out and buy some projectors. </TD></TR></TABLE>
there is no glare at all with that setup.. i have that exact setup on my gf's 2001 civic.. i remember back in the day i had to make my own H4 shields out of coke cans for my friends civics.. worked great.. the new version of those adapters is awesome.. they put a little pin in the shield so the bulb wont spin when you're trying to twist lock the igniter.. so this way, you can put the adapter and bulb in, lock it in place with the pins, then put the igniter onto the bulb.. with the old caspers ones, you had to put the adapter in, lock the bulb into the igniter, then try to put the bulb in, and lock down the pins with that big igniter in the way.. much more simple now.. plus the ebay ones are half price..
oh yeah, found some pics of my friends civic with my coke can shields
notice the bottom half of the reflector is dark.. no upward glare at all.
Old Dec 31, 2007 | 02:00 PM
  #37
y7turbo's Avatar
good pictures, thanks.
Old Dec 31, 2007 | 02:09 PM
  #38
Community Builder
any wall pics of the beam pattern from those shields in place?
Old Jan 1, 2008 | 08:03 PM
  #39
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">any wall pics of the beam pattern from those shields in place?</TD></TR></TABLE>
no.. but it looks just like the stock beam, just less glare.. it has even better glare protection than with an H4 halogen bulb in there.
Old Jan 6, 2008 | 07:54 PM
  #40
y7turbo's Avatar
well with just the casper shield, it was still horrible for me. I just made another shield that goes on to the casper shield.
here is 2 pics. the first one is just the pass side d2s bulb 4300k with the casper/y7turbo custom LOL shield.
this one is with the pass side hid and the driver side regular h4 bulb. LOL it looks the regular bulb has a **** load more glare.
I think i can live with this for a short time, Its a lot better than 100% than the drop in kits i see. i plan on getting some projectors soon, thats why i didnt buy a rebased type kit.
EDIT: i just got both in and wired up and im not to excited with the results. I had to make a larger shield just to cover the glare, this cuts down on how bright the lights are. Its not bad, just not what i expected.
looks like ill be ordering some projectors sooner than i thought. no big deal, i was gonna buy projectors anyway.
Modified by y7turbo at 1:01 AM 1/7/2008
Old Jan 7, 2008 | 04:17 PM
  #41
Genuine Rolla's Avatar
If you can bro, take some pics tonight....
doesn't look too bad...
Old Jan 7, 2008 | 05:11 PM
  #42
y7turbo's Avatar
Default Re: (Genuine Rolla)
edit:
Modified by y7turbo at 7:18 PM 1/7/2008
Modified by y7turbo at 7:20 PM 1/7/2008
Old Jan 14, 2008 | 08:47 AM
  #43
MestizoRacer310's Avatar
Default Re: 4300k vs 6000k? (jewpont)
There's something I have noticed between different brands of bulbs in regards to color. Some of them are "off" by a few hundred kelvin. For example, let's say brand A states their 6000k is "ultra white" yet brand B states their "ultra white" is 5300k or even 7000k.
How would a consumer know what color it really is?
To the OP, it basically comes down to how YOU want it...but I run 4300k in my TL's lows (which came w/ those from factory) and also 4300k in my wife's 98 accord w/ TYC projector headlamps. A retrofit w/ TSX projectors will be later down the line. I also run 3000k (golden yellow) in my TL's fog lights.
laocivic
Lighting
Dec 26, 2008 03:52 AM
itr1244
Aug 16, 2003 08:20 PM
E46M3CB
Feb 15, 2002 01:24 AM
