Wiring switch panel help please
Im wiring my race car,went and opted to eliminate all the unneeded accessories and functions and go with a basic race car switch panel for ign,fuel pump, etc etc.. I went with the kit xenocron is selling thier rocker switch panel with their micro relay junction fuse box i have all the wiring all the main power and ground to the junction box its fully wired to the switch panel also just stuck on getting power supply to my kpro, i eliminated the k series conversion harness but have the connectors which is the connector E which i only used the ign , and rpm signal wire the ignition wire is connected to the main switch panel switch qnd getting constant power when the switch is on through the fused relay and the c101 connector which i used the starter and the coil ground wires and ground that and connected the starter to switch panel like the ignition. I am getting no power to my kpro i just seeing if anyone has any experience wiring there vehicle like this and can weigh in with some info on something im soing wrong on something i am missing. Thanks in advance.
tub_sephiroth
May 9, 2007 07:35 PM
