New to the forum. Map issue. 2.4. 4 cylinder 2003
Im having a MAP issue. The car is running off
, missfire and no power. The reading is stating: Bad MAP sensor Running rich. I replaced the MAP sensor. I just changed the plugs and valve cover gasket. But still running bad. Any ideas? |
Re: New to the forum. Map issue. 2.4. 4 cylinder 2003
Compression test it.
Originally Posted by Micko699
(Post 51958066)
, missfire and no power. The reading is stating: Bad MAP sensor Running rich. I replaced the MAP sensor. I just changed the plugs and valve cover gasket. But still running bad. Any ideas? Make sure your IACV and MAP harness plugs are not reversed. Check MAP voltage and compare it to the service manual's voltage requirement. |
Thank you all for your response. I found the issue. It was the catalytic converter. I had one installed today. Runs great.
