k24a2 vs k20a2
Old Feb 20, 2013 | 02:49 PM
  #26
HondAl18's Avatar
Default Re: k24a2 vs k20a2
k20 u feel the hard pull
think about it k20a2= 200hp and k24a2=200hp
which is more agressive feel?
Old Apr 11, 2013 | 09:26 PM
  #27
memo_ksa's Avatar
K24A1 VS K20 type R ( FN2 )
3 K24A1 in dyno
Old Jan 1, 2014 | 05:16 PM
  #28
juconkey's Avatar
But why would anyone put a k20 head on a k24a2??
Old Jan 1, 2014 | 05:35 PM
  #29
Attarixep's Avatar
K20 cams have a larger VTEC lobe, also have the 50 degree VTC gear. So someone wanting to get a longer stroke and gain more torque but be able to have the higher lift on a "stock" block/head will gain from it. The deck height is also quite significant and valve-piston clearance on the K24a2 is tighter and can be risky at 50 degrees.
Old Jan 6, 2014 | 12:57 AM
  #30
juconkey's Avatar
Yeah and that gives you higher compression which equals more horse power. And if you want more lift put the cams in it. The compression you lose will hurt more then the little bit of lift you gain. That's why it don't make any since.
Old Jan 7, 2014 | 09:43 PM
  #31
Sccacivic1997's Avatar
K20 because I don't wanna run in In stu with a k24
Old Jan 19, 2014 | 10:30 PM
  #32
jmaesamh2b's Avatar
What about the JDM k18c?
FastEg6
Aug 26, 2010 11:23 AM
imnike9000
13
Nov 25, 2009 04:43 AM
Will_H
Jul 7, 2009 04:54 AM
turboedc2
20
Mar 8, 2006 08:18 AM
JBBNJ609
29
Apr 29, 2005 04:20 AM
