K-swap EK: Help, no spark
Hello guys :cheers:
I just swap my EK 99-00 with a K20a2. The conversion harness is a SparkksRacing, the calculator with an unlocked k100 and basemap for booting. When the ignition is on, the dashboard lights are on, the starter is running properly and there is fuel at the injectors, but no ignition! We restarted the timing chain cover to check the direction of the washer behind the damper and this is mounted correctly. Can it come from the Crank sensor or the camshaft sensor? All fuses are good, indoor and outdoor. It may be important to note that there is no alternator on the car (Important?). We are going to mount the new one at the next working day for testing. THANK'S A LOT! |
Re: K-swap EK: Help, no spark
Originally Posted by da_sherminator
(Post 51900416)
Hello guys :cheers:
