How do I fix this?
Old Mar 13, 2016 | 11:09 AM
kcinmd's Avatar
Default How do I fix this?
Knock sensor on K20Z1 in a 2005 RSX Type S.
Old Mar 13, 2016 | 01:28 PM
Runnerdown's Avatar
Default Re: How do I fix this?
Put a socket on the sensor, remove it, install a new one.
Old Mar 13, 2016 | 03:50 PM
kcinmd's Avatar
Did you look at the pictures?
Old Mar 13, 2016 | 06:28 PM
Runnerdown's Avatar
Yes I did. Looks like a typical broken knock sensor, what's the trouble with replacing it?
Old Mar 13, 2016 | 09:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
File or dremel two parallel flats into the base and then use an adjustable wrench to remove it. If that doesn't work, you could cut a pilot notch with the flat side facing left so that you can use a chisel or large flat blade screwdriver and hammer it loose by driving the tool in a counter-clockwise direction.
Old Mar 14, 2016 | 01:33 PM
Runnerdown's Avatar
It already has a hex, it it's just very thin.
2pac1
Jul 3, 2019 03:56 PM
b20beast83
Jul 21, 2008 08:41 PM
Throwdown
Jan 3, 2006 01:07 PM
gorilla nasty
Dec 5, 2003 02:14 PM
Dragger817
May 22, 2003 11:54 AM
