Help with a base map
Old Apr 16, 2023 | 05:02 PM
Sketchyeg's Avatar
Default Help with a base map
Anyone mind helping me with a base map for my kswap eg
i have a stock k24a2 with
stock eg fuel pump
rbc manifold
ebay 1200cc injectiors
1230 hood exit headers
kpro v4
Old Apr 16, 2023 | 08:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Help with a base map
Did your EBay 1200cc injectors come with Battery Offset/Dead Times/Latency values in a table ? If not, the only way you will get some basemap help is if someone has the EXACT same parts as you have and has tuned the engine. IF you have injector data, you can use the K24A2 tune in the standard KPro library and change the fuel injector size and dead times and you should be in the ball park.
00preludesipoop
Apr 27, 2005 01:40 PM
GDM Z28
Jun 19, 2003 11:54 PM
