cams (k24a2)
Old Feb 1, 2011 | 12:09 PM
near495's Avatar
Default cams (k24a2)
Trying to biuld a ksereis allmotor hatch... but cant realy find out wat kind of cams to go wit the motor.... Best bang for the buck..
set up- k24a2 long block
rbc intake (bored), bdl 72mm t/b, not sure on the header (asp?)
bdl feul rail, 1000cc injectors, k-pro, 6sp tranny, stage 5 comp-clutch..
let me know wat else i should have.... looking for 230-270hp????
Old Feb 10, 2011 | 11:44 AM
t.schultz's Avatar
Default Re: cams (k24a2)
Brian Crower has some nice cams out, also buddy club and skunk2.
Old Feb 10, 2011 | 03:12 PM
onefstek's Avatar
A stock k24a2 is going to struggle to make 270-280 whp. You will need to change a few parts.
Stefan
Old Feb 12, 2011 | 02:20 PM
95 Integra gsr's Avatar
12.5 PISTON and some nice cams .... k series blox b cams are ips k2 copys... just a heads up .... and check this guy out. for headers.http://www.k20a.org/forum/showthread.php?t=86726 or DTR/SSR
Old Feb 21, 2011 | 05:09 AM
near495's Avatar
realy blox k series b cams are replicas of ips k2's... that header is ****ing nasty....
you realy think k24a2 is realy not going to make that power....
Old Feb 21, 2011 | 12:31 PM
i made 211/176 on a stock k24a2/k20z3 frank on stock tsx head/downpipe and tsx factory cat. i can see a stock bottom end k24a2 with some bigger cams and a decent header no cat. on kpro around 250ish i would say. the tsx cam sucks unless you have an 06 tsx long block.
gnxpro24
Apr 24, 2014 06:12 AM
EMwUnDuH
Aug 18, 2006 08:24 AM
SiKnezzALLmotor
26
May 12, 2006 09:15 PM
txracer
Oct 14, 2004 03:10 PM
Tuan
Jan 15, 2003 10:23 AM
