09 si won't start
Old Jul 14, 2014 | 09:19 PM
Eldubsbro1's Avatar
Default 09 si won't start
Still having the same problem with the car it needs starting fluid to idle properly and run . It gets fuel pressure at the ktuned fuel rail. It gets spark. The fuel lines are brand new.has brand new oem injectors. New speak plugs. The fuel pump was tested out of the car and works fine. The car throw a p1077 code which is imrc valve is stuck open. Really still need y'all's help!! I had a new ECu put in it bc the old ECu had hondata on it n had it married to the car but found out the new ECu was for a 1.8litre auto vtec . Would that effect it?
Eldubsbro1
Jul 13, 2014 09:54 PM
lifethinker
Apr 21, 2014 01:04 PM
La_Pieuvre
24
Jan 5, 2007 07:27 PM
crxzcracer
25
Dec 3, 2006 11:55 AM
