What's up
Old Mar 16, 2020 | 11:27 PM
Fernando Frias's Avatar
Default What's up
New to this forum came across when i got my 96 db8 with a b20b and gsr trans.
Old Mar 17, 2020 | 10:22 AM
roddrick's Avatar
Premium Member
5 Year Member
Default Re: What's up
welcome to the forum, you have a nice platform i'd like to see a build thread on sometime.
Old Mar 17, 2020 | 10:34 AM
yeah she has been good to me just did clutch and little stuff here and there. Next thing im thinking on doing is getting a base map for the b20. Currently running p75 ls ecu. I took it to the track a couple times with some friends and best i got was 15.6 with clutch starting to slip.
Old Mar 17, 2020 | 11:16 AM
roddrick's Avatar
Premium Member
5 Year Member
what clutch setup did you go with? I've had a b20b with b16 transmission. It had good low end and mid range but nothing on the top end.
Old Mar 17, 2020 | 11:25 AM
i went with stage 1 excedy with lightweight flywheel. Can feel noticable change in performance. Yeah mine gives good power till about 6,000 rpm. I'm hoping that a base map can help that out. Still have to go test with new clutch and tires but unfortunately the track shut down for the corona.
Old Mar 17, 2020 | 11:30 AM
roddrick's Avatar
Premium Member
5 Year Member
unfortunately there won't be much to gain up top with the non vtec b20. It stops pulling after a certain range and the valvetrain is not good for turning high rpm's. That was from my experience. The corona epidemic is shutting down alot of business. I held back on going farther at this time with my build until this passes
Old Mar 17, 2020 | 11:33 AM
yeah I don't plan on revving that high just hoping for at least 7200rpm I was reading up on running an LS ECU and people say your runs a little lean up top
Old Mar 17, 2020 | 11:47 AM
roddrick's Avatar
Premium Member
5 Year Member
I was unaware at the time that it was not a rev friendly engine. I can't remember if the a/f ratio up top was lean but I was running a p28. This was about 10 years ago though. There is not many non vtec b series build's anymore and not many upgrades for gains without boost
Old Mar 17, 2020 | 12:04 PM
I also have the p8r head. I have a local shop that does custom regrinds on cams for 150 to 180 you think that would be worth it? I am also running full interior maybe I should shed some weight on it help improve times
Old Mar 17, 2020 | 12:21 PM
roddrick's Avatar
Premium Member
5 Year Member
I've not had a regrind to a camshaft myself. There is a discussion about this on the forum i ran across when thought of doing the same but really couldn't find enough info on it. There is camshafts that are around the same price i saw awhile back though.
Old Mar 17, 2020 | 12:31 PM
I think I'm just going to 150 shot it haha I hope she can take the abuse
Old Mar 17, 2020 | 12:43 PM
roddrick's Avatar
Premium Member
5 Year Member
That's a pretty hefty shot i'd say for myself. I am looking into a 75 shot on my setup.The p8r head with really good porting and a crower camshaft (cheapest i've found) with a good intake manifold/throttle body combination i'd say would be better option vs the P75 head on a shot.
Old Mar 17, 2020 | 01:44 PM
Haha yeah way to much. Also what are your thoughts on running a .48 trim turbo (about same size mr2 turbo) on like 6psi. Im thinking this size so i can have boost coming in around 3300 rpm. I've drove my friends mr2 and like the power band it has.
Old Mar 17, 2020 | 02:51 PM
roddrick's Avatar
Premium Member
5 Year Member
That size on the hot side is good for quick spool. What compressor size will you be running? This could net you that 250hp-350hp range without too much stress on it and of course it's more variables to it
Old Mar 17, 2020 | 08:28 PM
About 250 sounds nice still able to daily and enough juice to surprise some. I also have a 92 integra rs with a b20b and cable gsr. Want to turbo one and throw a b16 head on the other not sure which.
AlphaTeg713
Aug 11, 2014 04:43 PM
gliaw
Oct 16, 2002 03:39 PM
