Turn signals are not working
Ok so this is drving me insane, The hazards work but the turn signals do not. I replaced the Flasher relay on the wiring harness, the light and signal switch on the steering columns. My brake lights etc all work so its not the fuse in the fuse box. Also replaced the hazard switch just in case and no go. This is a 93 del sol S with a 1995 del sol SI dash harness swap, everything but the turn signals work but I am not sure if this harness is different.
Also this is the light switch, the three pin plug on the top, is that supposed to be connected? it wasn't and I cant find a cable that is supposed to go there. If something even goes there.
The hazards work and they turn on when the headlights are on just don't blink
Skylark
Apr 14, 2015 07:16 AM
rhartman0922
14
Jun 13, 2011 10:33 AM
matt56
Jun 27, 2009 05:58 PM
