New member Need help with trouble codes
Old Feb 24, 2018 | 01:49 PM
Chris Cleary's Avatar
Default New member Need help with trouble codes
New member here looking for help in trouble codes for my fiancé’s 2002 Honda CR-V EX.
P1259
P0325
P1166
P1167
P1456
P0845
Old Feb 24, 2018 | 04:25 PM
HPPMike's Avatar
P1259 - VTEC System Malfunction
P0325 - Knock sensor malfunction
P1166 - 02 sensor sensor 1 malfunction
P1167 - 02 sensor sensor 2 malfunction
P1456 - evap leak - Most common leak is gas cap
P0845 - Transmission Fluid Pressure Sensor/Switch 'B' Circuit
i would have these fixed as soon as possible or you could damage other components, those issues are vital to having the car running properly.
Old Feb 24, 2018 | 04:41 PM
Chriscleary86's Avatar
Default Re: New member Need help with trouble codes
I had to make a new account cause the other one was messed up. Are those fixes easy enough for someone to do by watching how to videos?
Old Feb 24, 2018 | 04:49 PM
HPPMike's Avatar
The 02 sensors and the knock sensor are fairly easy depending on where they are located, you will need some tools to tackle those jobs. As far as the transmission, vtec and evap leak those require some knowledge in diagnosis and may require specialty tools to find the issue. I have 15 years experience in the automotive industry and also ase certified.
Old Feb 24, 2018 | 05:48 PM
Someone was saying the EVAP leak could be a gas cap? Whenever I put gas in her car the gas cap has always felt weird when I unscrew it like it’s harder than normal. Can I buy aftermarket cap or will that keep the code on?
Old Feb 24, 2018 | 05:53 PM
HPPMike's Avatar
I would purchase a factory gas cap from honda, easy way to check is pull the cap off and inspect the seal on it.
Old Feb 24, 2018 | 08:05 PM
toyomatt84's Avatar
Sanji
Banned the duplicate account. If you want that account instead, let me know.
Old Feb 24, 2018 | 08:33 PM
Thank you. I was just having trouble logging in cause I registered from Facebook so it was all weird. But I bought a gas cap and deleted the codes. Put the new cap on and the check engine light came on again. I rescanned the codes and only 2 came up. P1166 and P1167. Only drove about a mile so I will rescan after driving a little more and see if that fixes things.
Old Feb 26, 2018 | 03:01 PM
HPPMike's Avatar
Sounds like you def need to replace the 02 sensor, if it came up immediately after clearing them i would also check the connectors and wiring going to those sensors. Most times it will take the car a couple of key cycles before the codes come back up. it needs to see the issue a couple times before it throws the code again. you want to check pending codes in the scanner if yours has that option, that will let you know what other codes the computer has stored.
prostreetonline
Jul 10, 2004 12:21 PM
