Gsr build
Old Aug 31, 2014 | 07:41 PM
97dcteggy's Avatar
Default Gsr build
So i wanted to build a whole gsr motor from the ground up pretty much. I just got the block today, (bare block) anyone have suggestions on what size to bore it too without getting new sleeves? And could anyone provide a list of all sensors i will need. Thank you
Old Sep 1, 2014 | 07:12 PM
delsol-101's Avatar
Default Re: Gsr build
bare block. man theres not much u can do with boring if u dnt want to sleeve but u could go .5 safely over bore i would recommend b16 pistons p30's
and a ls crank with ls rods for the best stroke
sensors
knock sens
water temp sensor
fan switch sensor
oil pressure sensor
well my memory stops there good luck on your build
Old Sep 5, 2014 | 07:32 PM
97dcteggy's Avatar
Thank you.
ej6sir-t
Jan 4, 2012 05:47 AM
bb6guy
Oct 25, 2010 04:27 PM
SkertySkerty
Jul 4, 2007 04:21 PM
Brian_92GSR
Mar 27, 2002 09:17 PM
spoolin342
Feb 7, 2002 09:39 AM
