Hello all. I've been a member for a while, but getting back into the Honda life again. I picked up a pretty clean sedan(body wise at least), and am about to start the process of fixing some of the dirty things that have been done to it. I will probably start a clean up thread soon. More pics to come.
Welcome to the forum and congratulations on your purchase, hope you can give us updates about the restoration you're planning. Good luck and have fun!
thanks man. Can't wait to be able to post and start threads. I just replaced the starter and I can start it but my damn cluster is bouncing. I don't mind swapping a new one in but the mileage I Want to match. The shell has 298k the motor has about 50k on it now. Would be nice to have a tach too.
Thank for the replies, Got some goods today!New shift linkage pin(put the car on a lift and found the linkage to be held together by a 6mm bolt, very sloppy) and radiator, also energy suspension shifter bushings Hopefully will have a chance to install this weekend.
Thanks, I have a lot of plans for it(not much time). There's a lot of wiring cleanup to be done and a lot of suspension, but for the most part it's not too bad, I'm just happy to have a pretty clean body to work with.
