yo timing difference with f22a and h22a are they the same?
Old Jun 14, 2003 | 12:42 AM
preluder's Avatar
Default yo timing difference with f22a and h22a are they the same?
will a automatic reprogrammed into a 5-speed for a h22a drive funny or idle funny with the tps sensor and the idle air control sensor. If its a j-spec motor is the timing different will it run lean and damn near bog out. Cause thats what im getting on mine whats the timing for my j-spec. Oh i already changed the fuel filter everything having to do with fuel economy . what could it be?
Old Jun 14, 2003 | 05:04 PM
junglerunna's Avatar
Default Re: yo timing difference with f22a and h22a are they the same? (preluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluder &raquo;</TD></TR><TR><TD CLASS="quote">will a automatic reprogrammed into a 5-speed for a h22a drive funny or idle funny with the tps sensor and the idle air control sensor. If its a j-spec motor is the timing different will it run lean and damn near bog out. Cause thats what im getting on mine whats the timing for my j-spec. Oh i already changed the fuel filter everything having to do with fuel economy . what could it be?</TD></TR></TABLE>
So are you trying to figure out why your car is idling funny. I can not quite comprehend your post.
nrmskate
Sep 19, 2013 02:28 PM
EF9Infantry
Jan 6, 2012 11:44 AM
zpizzle07
Aug 20, 2008 09:36 PM
