wiring truble
iam using a obd1 b18a to do a ls vtec swap with a b16a1 head what do i need to put it in my 4th gen std hatch?i need wiring diagrames,mounts and maybe a jdm style hood..but can anyone give me a wiring diagram for this of tell me where to buy a conversion harness> thanks
mike
mike
First thing, is your car multi-point or dual point fuel injection? If it is dual point (2 injectors) then you will have quite a bit of wiring. If you are running multi-point then all you need to wire is VTEC, knocksensor, and o2 sensor. All the wiring info you need can be found at http://www.hasport.com . Good luck.
