Will these pistons work?
Old Aug 20, 2003 | 10:44 AM
xpracing's Avatar
Default Will these pistons work?
I have a 1st gen b16 swapped into my hatch and about a month after I put the turbo on it started puffing a lot of smoke. So, I did a compression test and 1-3 read around 190 and #4 read just below 90. So, I pulled the head off and the #4 piston out, to find out that I was able to pull 5 chunks off of the piston between the rings. And my question is will a USDM b16 piston work on my 1st gen JDM motor or is the compression going to be different?
Thanks
Brian
Old Aug 20, 2003 | 02:02 PM
CRXBart's Avatar
Default Re: Will these pistons work? (xpracing)
ah why don't you try using the search function. it is the button in the top right.
Old Aug 20, 2003 | 02:52 PM
TurboJesse
Guest
Posts: n/a
Pretty sure it will work...but why replace with a forged piston? since you already have the engine apart.
Old Aug 20, 2003 | 06:45 PM
irev210's Avatar
usdm is pr3
89-91 jdm is pr3
if your piston reads pr3 on top, then head to ur local honda dealer and u can order one piston
if u want u can buy a set of used pistons/rods for about 50 bucks
might want to check clearances though, might need to go with .25 over pistons
Old Aug 21, 2003 | 10:01 AM
xpracing's Avatar
Default Re: Will these pistons work? (Mpir3)
I really wish I had the money for aftermarket pistons. But I kinda got screwed on money when I spent about 900 bux on new rims for my other car and then a couple days later someone stole my wallet that had about 600 bux in it from selling my old rims.
Old Aug 21, 2003 | 10:03 AM
xpracing's Avatar
Default Re: Will these pistons work? (CRXBart)
Damnit Bart I was standing 5 feet away from you when you posted that. Keep this up and I may just sell your tires
Old Aug 21, 2003 | 11:00 AM
CRXBart's Avatar
Speaking of my tires where the **** are they? I paid you for them like 5 months ago you delinquent ****! I want my mudda ******* Azenies biatch!
NOTDISFA5
34
Oct 10, 2010 12:01 PM
unknown0001
Mar 25, 2006 10:39 AM
92eg6lsvtec
Jul 2, 2005 07:22 AM
scrubachu
Nov 20, 2003 12:07 PM
ghosts
Oct 6, 2001 04:51 AM
