Will a cx harness run an ex engine???
Old Aug 9, 2002 | 03:01 PM
GreenBean's Avatar
Default Will a cx harness run an ex engine???
I have a 94-cx with a 95-ex engine...
Will not run at all...
Could it be the engine harness...
That is the only thing I have not swapped out yet...
Do any of you out there have a swap in a cx hatch using the factory harness...
I have no spark but know the dist is good cause I swapped it into my buds 95-ex
and is ran just fine...
Any thoughts...
Old Aug 9, 2002 | 03:35 PM
memphiss13's Avatar
Default Re: Will a cx harness run an ex engine??? (GreenBean)
add the vtec wires
Old Aug 9, 2002 | 03:59 PM
memphiss13's Avatar
Default Re: Will a cx harness run an ex engine??? (rookie2nr)
if your harness is messed up i have a LS harness that i will sell you for $75 it will hook right up, but you still have to add the vtec wires.
Old Aug 10, 2002 | 05:56 AM
GreenBean's Avatar
Are you running the factory harness...
I am and i have ran the wires for vtec and my other wires for the
4-wire o-2 sensor...
There is swap shop telling me it is my harness...
That I would have to install a 92-95 ex or si engine harness.
Lil Rick
Jan 27, 2011 10:08 PM
DACteg
Nov 6, 2008 08:02 AM
hb90racer
Feb 1, 2005 08:59 PM
Lmgrcivic
Jan 15, 2005 03:34 PM
SLowCrx
Dec 16, 2003 02:27 PM
