Where is my map sensor plug
Old May 10, 2004 | 03:31 PM
zlambe's Avatar
Default Where is my map sensor plug
The car a 92 vx I am swapping in jdm b16a came complete with full wiring harness but no map sensor or wiring or plug for one. The shock tower harness has four plugs but no plug coming off for the map sensor. Wirng harnesses matched up except that fourth plug. WTF!!!!! Anyone have any ideas. I searched everywhere but cant find anything.
Modified by zlambe at 5:08 PM 5/10/2004
Old May 10, 2004 | 04:38 PM
xcchicx's Avatar
Default Re: Where is my map sensor plug (zlambe)
you might have gotton the wrong wiring harness. it might be pre-obd that you were given to use. my friend had the same problem and ended up just using the old wiring harness.
Old May 10, 2004 | 05:22 PM
zlambe's Avatar
Default Re: Where is my map sensor plug (xcchicx)
The wiring harness that came with the motor is the right one its the one on the car that is different. I guess i will have to use the vx wiring harness . Anyone else have any ideas
thez6kid
Engine Management and Tuning
May 13, 2012 04:46 PM
turboblack2door
Jun 8, 2008 09:24 AM
egmatt93
20
Mar 7, 2008 07:00 AM
Mannykiller
Aug 6, 2007 03:57 PM
bmw626
Aug 22, 2005 07:30 AM
