Where to attach cherry picker to motor?
Old Nov 11, 2002 | 05:06 PM
turbod16y7vtec's Avatar
Default Where to attach cherry picker to motor?
what are the best places to attached the motor lift to the motor so its balanced out the most?
Old Nov 11, 2002 | 05:26 PM
poison's Avatar
Default Re: Where to attach cherry picker to motor? (d16y7vtec)
depends on the motor, usually a very strong bolt (tranny bolt), or mount bolt that you can wrap the chain around.
Old Nov 11, 2002 | 06:41 PM
Jackson's Avatar
Default Re: Where to attach cherry picker to motor? (poison)
I have seen you make a lot of posts that make no sense or you have no clue what you are talking about. If you dont know the answer, dont post!
As for attaching the harness, use a tranny bolt on the front of the tranny and a 14mm bolt on the timing belt side on the backside of the head.
[Modified by Jackson, 7:42 PM 11/11/2002]
Old Nov 11, 2002 | 06:46 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Where to attach cherry picker to motor? (Jackson)
yep, he said a mouthful, there u have it
Old Nov 11, 2002 | 07:14 PM
hondaZvic's Avatar
are u an idiot? how is what poison said not making any sense? what he said makes perfect sense.. then u talk shiet.. and say the same thing he said.... OMG!!!!!!!!! U he made a perfectly reasonable answer, and u knock him down? do u not have anything better to do....?.......
Old Nov 11, 2002 | 07:43 PM
poison's Avatar
wtf?
What I posted makes perfect sense, who does it NOT make sense to. Especially since I said the EXACT same thing as you; only you were being more specific when the dude was lookin for 'ideas' on where to mount the cherry picker chain.
make sure you have ground to stand on before you stand your ground
Old Nov 11, 2002 | 07:50 PM
Jackson's Avatar
Make sure you think before you type. It is not just this post, I have seen other ludicrous posts of yours.
Old Nov 11, 2002 | 07:58 PM
poison's Avatar
Uhh, what I post, dude is based on my experiences. I know what I am talking about and do not talk out of my ***.
what I post, i explain in detail......if any of my posts don't 'click' and make sense , show me, i'd be more than happy to explain to you what i mean.
word of advise, bro don't flame people who you have no idea of their background.
Old Nov 11, 2002 | 08:12 PM
Jackson's Avatar
I am not trying to turn this into a flame contest. But for example...
"what are the best places to attached the motor lift to the motor so its balanced out the most?"
Your answer...
"depends on the motor, usually a very strong bolt (tranny bolt), or mount bolt that you can wrap the chain around."
And this one...
"which throttle cable and heater hoses? 2000 B16a2 into a 96 civic."
You said...
"You can use the stock throttle cable, just need to mount the bracket on the intake manifold to hold it in place."
What is that? Of course the throttle cable bracket mounts to the intake manifold. Give people the correct answers. The correct answer would be to use the si throttle cable. Not to rig some fucked up way to make it work.
I am not trying to be an ***, but he wanted to know where not what to use. Using the tranny bolt as you mentioned was right, but he has no idea where to put it. A lot of people who post here are still learning. So you shouldnt ***-u-me they know everything.
Old Nov 11, 2002 | 08:13 PM
Jackson's Avatar
I am sure you are "Ricky Racer" in your hometown with your h22 powered civic, but I really dont care.
Old Nov 11, 2002 | 08:42 PM
MJ23FE's Avatar
Poison is the shiat!!! Jackson is just a ****** ******!!!
[Modified by MJ23FE, 12:46 AM 11/12/2002]
Old Nov 11, 2002 | 08:44 PM
poison's Avatar
It's called common sense man. The stock civic one WILL work, and is not 'ghetto' and 'fucked up way'. He could also use the Si throttle cable.
I don't want to start arguing on what can or can't be used or turn it into a flame war either.
I admit the above post was a little 'broad' and not specifying more clearly on what bolts, that is why I said "depends on what motor", and I said where people 'usually' put the bolts. Any bolt that is strong enough will work. What you were saying was correct and more specific, but you also assumed he was installing some B series motor which you probably did on your car, which was your mistake.
I don't want to shut you down man, nor do I want to have disagreements over BS. But i know what I am talking about, and sounds very well that you do as well.
I don't just 'talk out of my ***' to help people, otherwise i won't post, it's common sense.
Old Nov 11, 2002 | 08:45 PM
poison's Avatar
and with that "ricky racer" flame, that was just gay dude. You thinking I am coming across as a 'know-it-all' and thinking I am bad ***......was, yet another one of your "assuming" and was completely gay.
Congrats....you're now a bad ***
Old Nov 11, 2002 | 08:47 PM
MJ23FE's Avatar
Congrats he is now a ******!
Old Nov 11, 2002 | 08:49 PM
NWPNOMORE's Avatar
Banned
Default Re: Where to attach cherry picker to motor? (MJ23FE)
there you go, that's the smart thing to say. I bet poison feels like a big man with people like you boosting his internet ego. Wipe that brown **** off your nose.
[Modified by NWP4LIFE, 9:51 PM 11/11/2002]
Old Nov 11, 2002 | 08:52 PM
MJ23FE's Avatar
Default Re: Where to attach cherry picker to motor? (NWP4LIFE)
[QUOTE]Poison is the shiat!!! Jackson is just a ****** ******!!!
[QUOTE]
What is this??? ******s night out??? Stay away!!!
Old Nov 11, 2002 | 08:55 PM
The Mole's Avatar
this was a perfectly good thread and question....turned to gheyness
silver eg has returned from the nissan fantacy land
Old Nov 11, 2002 | 09:03 PM
yellow blur's Avatar
Oh my god, you got some bad *** mods in your signature.
Old Nov 11, 2002 | 09:04 PM
MJ23FE's Avatar
Default Re: Where to attach cherry picker to motor? (yellow blur)
Thats why i call it a POS, yah ****** ******!!!
Old Nov 11, 2002 | 09:05 PM
NWPNOMORE's Avatar
Banned
for reals, i wanna see pics of that 90 accord, it must be tiiite with an owner that acts so hard on the computer.
Old Nov 11, 2002 | 09:06 PM
Do you have some infatuation with ******s? Are you one yourself? You look like a dumbass posting all this nonsense.
You should take the time to remove those mods from your signature because it makes you and your car look stupid as ****.
Old Nov 11, 2002 | 09:09 PM
NWPNOMORE's Avatar
Banned
i found pics of his car
hondaZvic's Avatar
OMG!!!!!!!!! this blew way up!!!!!!!!!! ahahhahahahha poison
Old Nov 11, 2002 | 09:10 PM
MJ23FE's Avatar
If peeps can list their altezza's... than i can list my stereo set-up.
I have no infatuation with ******s, just an infatuation with pointing them out.
For example yellow blur.
And we cannot forget NWP4LIFE.
Jackson's Avatar
Grow up!
