what compression ratio do you get....
Old Sep 4, 2002 | 03:22 PM
GRIMEY.STREET.RACER's Avatar
Default what compression ratio do you get....
What compression ratio do you get when you use ITR pistons in a B16 block...
will it make a difference with the B18c1 crank or is it better to use the B16 crank...
Old Sep 5, 2002 | 03:41 AM
Jeff C's Avatar
Default Re: what compression ratio do you get.... (GRIMEY.STREET.RACER)
see if this helps...
http://www.c-speedracing.com/howto/c.../compcalc.html
hovic
Mar 6, 2013 10:59 AM
7rrivera7
Jan 25, 2010 06:45 PM
silent-chris
May 5, 2005 09:20 AM
7rrivera7
Oct 20, 2003 04:55 PM
