vtec lockup silenoid
Salvage them off of another wire harness or else just cut them off and use an electronic spade terminal. Any electronics store should carry a male/female set of generic plugs and they'll all work. Find a set that has a moisture seal in them. If you're really in a pinch just solder a wire to the VTEC solenoid wire and bypass the connector all together.
civic_boy23
Feb 2, 2007 07:15 PM
