VSS on the tranny...
Old Oct 3, 2002 | 06:41 PM
baonest1's Avatar
Default VSS on the tranny...
sup guys, this Q is for the tranny gurus, or whoever wants to help. i have a ITR tranny.. and the VSS is broken on it. now i was told i could swap my VSS out of my other tranny. then it hit me that my other tranny is an LS. could this still be accomplished. if i cant swap, the VSS is complete, just the plastic casing is broken off of it, i doubt its a good idea but is there a way i can rig it in there.
thanx
Old Oct 3, 2002 | 06:56 PM
tonyxcom's Avatar
Default Re: VSS on the tranny... (baonest)
just try your other one and see if it works.
You may also be able to take just the top of your LS VSS and swap it to the bottom of the ITR one. There are 3 bolts, two of them will allow you to take the top off. It should be pretty easy to see.
Old Oct 3, 2002 | 07:14 PM
memphiss13's Avatar
Default Re: VSS on the tranny... (tonyxcom)
its all the same, i used my VSS from my b16 tranny in my ITR tranny sense i had just replaced it before i blew it.
Old Oct 3, 2002 | 08:09 PM
baonest1's Avatar
Default Re: VSS on the tranny... (rookie2nr)
sounds good guys, yea i went ahead and switched them. they fit. im pertty sure there is no real difference b/w the two
thanx again
Old Oct 3, 2002 | 08:38 PM
tinkerbell's Avatar
check this!
i used my 1983 prelude VSS on my JDM B16A tranny(J1)
just FYI,
t..
Old Oct 3, 2002 | 08:39 PM
baonest1's Avatar
Default Re: VSS on the tranny... (tinkerbell)
check this!
just FYI,
t..
holy moly.. talk about saving money. haha damn so its been working find and dandy?
Old Oct 3, 2002 | 08:40 PM
tinkerbell's Avatar
saving money?
nah man, the Prelude powersteering rack had a different configuration to the JDM sensor, so i had no choice (since the B16A is in my 1983 Prelude!)
t..
Old Oct 3, 2002 | 08:42 PM
baonest1's Avatar
well i guess not saving money.. i just had nothing better to say. haha.
so the VSS doesnt matter if its vtec or not. they will all just about work on each othr
Old Oct 3, 2002 | 08:44 PM
tinkerbell's Avatar
yep, i guess so, all that matters is that it fits in the hole and has the smae pinion gear...
t..
jdm89crxhf
Nov 29, 2011 07:23 AM
zhan28
Nov 20, 2006 04:45 PM
OMG WTF
Jan 28, 2006 08:04 PM
Boosted EP
Aug 19, 2004 10:33 PM
