Using a Skunk2 intake manifold on a B20b
Old Aug 13, 2014 | 06:04 AM
CCFM563's Avatar
Default Using a Skunk2 intake manifold on a B20b
I have found some info on this but frankly do not know what to type into the search bar to get a specific answer. So maybe one of you experts can clear this up.
I have a 99 JDM B20b with the high intake manifold. I know I have to remove it for the LS/Skunk 2 manifold. I have the Skunk 2 manifold and TB.
The car it's going into is a 97 Lx Ek non-vtec I will be running a OBD 1 ECU with the OBD 2 harness and jumper.
My question is: What injectors, fuel rail, fuel pressure regulator, fuel lines, throttle cable do I need? I was told the ones out of a 96-00 Integra LS or B18b is what I need but also read that I can use my B20 injectors as well. I'm pretty sure I need an LS throttle cable as well.
Thanks for your help
Trojan Man
Oct 20, 2014 04:25 AM
wrXtian
Jan 25, 2003 06:30 PM
DevinW
Sep 11, 2002 09:13 AM
ef ect
Apr 2, 2002 08:12 PM
