using DSM injectors
Old Jul 10, 2004 | 12:13 AM
krazykoncept's Avatar
Default using DSM injectors
some one told me i could use DSM injectors for my small turbo set up. I have a 92 civic hatch with a D16z6 and p28 computer. I just want to upgrade my injectors alittle. Can anyone tell me witch one to use something about blue top injetors?
Old Jul 10, 2004 | 11:47 AM
beaterdriver's Avatar
i think u need to use a resistor box when u use the dsm injectors. atleast that what my friend did when we turbo'd his car
Old Jul 11, 2004 | 10:20 PM
blackeg's Avatar
Default Re: (beaterdriver)
you can also go to radio shack and get inline resitors. 10 ohm/10watt resistors. they come in packs of 2 for like 2 bucks. inside the engine bay on the drivers side strut tower are 4 dark yellow/black wires and 4 light yellow/black wires. cut the dark yellow/black wires and solder the inline resistors into those wires(1 resistor per wire) thats what i did to install my dsm blue tops into my 93 ex and it worked with no problems. your also gonna need to dremel out the rubber gasket that goes between the injector and the intake manifold, cause the dsm injectors are fatter at the bottom then civic ones. once you do this tho, you will probably need some sort of tunable fuel management to make the injectors idle properly and **** like that (uberdata )
Old Jul 15, 2004 | 12:18 AM
Default Re: (blackeg)
THANKS FOR THE INFO GUYS At this time I only can get my hands on a set of injectors from a 92 talon NA dohc I know its not blue injector but will they work. I also can get my hands on a set of B16 injectors wil this work insted?
Old Jul 15, 2004 | 05:35 AM
93H22ACX's Avatar
Default Re: (krazykoncept)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazykoncept &raquo;</TD></TR><TR><TD CLASS="quote">THANKS FOR THE INFO GUYS At this time I only can get my hands on a set of injectors from a 92 talon NA dohc I know its not blue injector but will they work. I also can get my hands on a set of B16 injectors wil this work insted?</TD></TR></TABLE>
you only want to go up a couple of cc's like 10-20cc? Either get 97-up prelude injectors 290cc high resistant or 93-95 prelude vtecs 345cc low resistant
EJ8CIVIC
Mar 20, 2007 08:36 PM
TURBO DC2
May 6, 2005 06:36 AM
J2turbo21
Aug 16, 2003 05:43 PM
