Upgraded ecu recommendations
Old Feb 22, 2005 | 06:17 PM
pawz1200's Avatar
Default Upgraded ecu recommendations
Thinking about jdm h22a going into 96' hatch again. Have the p13 ecu and was looking to upgrade to a chipped ecu was wondering what people are using/recommend. I see there are a few, JUN, Skunk? Which one is best for street set-up, daily driver.
Also opinions on skunk2 stage one cams? I was thinking of doing them only do not have cash to do stage two and all the upgrades needed! Is it worth just doing stage one cams only?
Thanks for info!
Old Feb 23, 2005 | 05:20 AM
Adam.'s Avatar
Default Re: Upgraded ecu recommendations (pawz1200)
It completely depends on your setup.
Chipped ecu's aren't perfect either. The big thing I don't like about them is that they take a motor that is going to be run to the limit, and essentially guess at what the proper settings for the limit should be.
For a couple hundred more (almost all of that in dyno time), you can have uberdata running and completely tuned out ecu that is made specifically for your car.
stock ecu, good
chipped ecu, better (usually)
uberdata/hondata/crome, best
peck1005
Mar 20, 2008 05:31 PM
98itr0448
Oct 5, 2004 01:42 PM
junya16
11
Jan 22, 2004 01:27 AM
AK94GSR
May 28, 2003 02:01 PM
