type r or not type r
Old May 14, 2013 | 11:48 AM
nate808's Avatar
Default type r or not type r
Hi im a newbe to this fourm and im trying to figure out if my motor is indeed a type r or not. I looked in all other type of fourms and they all have good points to look for as well as I called my local honda dealer. So my question is this. Is in fact my head a possible type r or not. My car is a 97 civic ex with a b16 swap. I looked in other fourms and I found to look by the distributor for green paint mine has my head cast number is pr3-1 year is not certain yet as its my daily driver. with stock exhaust manifold I looked for valve springs and I belive I do see dual valve springs per valves. Now im just wondering if by that info it is a possible itr. And should I check cam or intake ports. As well as is it easy to just pull of the cam cover and tell that way or do I need to pull off the cam itself. Sorry for newbe qusstion and a beed around the bush story but in help anyone can give me is greatly appreciated?
Old May 14, 2013 | 11:52 AM
TypeRfit's Avatar
RESIDENT
Default Re: type r or not type r
ITR/CTR/JDM GSR/B16 could be a pr3-1.Take pictures of cam ends and valve springs.
Old May 14, 2013 | 12:06 PM
nate808's Avatar
Ok ill try take pic of cam ends. Do u kno if cam cover plate bolts is torque to yeld bolts . Where I need to replace with new bolts after I remove them
Old May 14, 2013 | 12:08 PM
pennies_hatchie's Avatar
Are you looking to see if you have a B16B (CTR) motor or a (B18C) (ITR) motor. You just said you have a B16, so if you think you may have an ITR motor, take a look at the stamp on the block to see if it says B18C. If it says, B16A, then you have a B16 motor.
All B16/ITR motors have the PR3 cast heads and it's easy to swap parts/blocks. Take some pictures of the whole motor/engine bay, then of the block stamp and other pictures of the motor and we'll be able to help you more.
Old May 14, 2013 | 12:26 PM
JuggerNaut-CTR's Avatar
jdm gsr is still a p72 casting
Op...look here for the year
If it has the dual springs on both in. and ex. sides, itr/ctr cams, the p73 intake manifold, and the year is in range...should be safe to assume its a type r head.
Old May 14, 2013 | 12:36 PM
nate808's Avatar
Well I looked at my block stamp and it is indeed a b16 block. But as I read posts on ddifferent fourms they all talk about Iidentifing the b16 type r head. So I looking at mine and would like to find out as well. The true only reason I looking into this research is im looking into upgrading my cam to a type r or even a stage 1. But if I already have a type r head then I just need to find out if I have the correct cams to go with it.
Old May 14, 2013 | 12:38 PM
TypeRfit's Avatar
RESIDENT
IIRC, Jdm ITR, CTR and GSR are all p72 casting. I'll go look on my CTR right now.
Old May 14, 2013 | 12:42 PM
Your recalling is incorrect
itr/ctr = pr3
usdm gsr / jdm gsr = p72
Old May 14, 2013 | 12:47 PM
TypeRfit's Avatar
RESIDENT
itr/ctr = pr3
My bad.
Old May 14, 2013 | 12:49 PM
Its not uncommon for one to upgrade their b16 cams for itr/ctr cams. Its a cheap upgrade. If they are indeed itr/ctr cams, just remember...doesn't mean the entire head is a type-r. FYI
My bad.
You're good dude
Old May 14, 2013 | 01:11 PM
nate808's Avatar
Yeah thats why im doing this research because the shop that did the motor swap may have put stock b16 cams in instead of leaving the itr cams in. This car is my wifes car and when I met her this car was bad for actually holding the honda name on it. So now after I got motor wiring correct speedo working, tach working, vtec opening when it should. Now im just trying to find if the head is possible an itr head with correct or wrong cams in it. someone told me that stock b16 intake mani does not bolt up to type r heads.Could ssomeone verify this for me if it is true or not ?
Old May 14, 2013 | 01:14 PM
TypeRfit's Avatar
RESIDENT
You're good dude
I'll never doubt you again.
Old May 15, 2013 | 12:11 AM
nate808's Avatar
Ok im back. I looked in the motor took off the cam covers and exposed tye ends. So ill post pics in a bit. I also took off the exhaust manifold cover to get the year of cast. Wasn't able to take pic of year but the year of cast is "91" the cams I belive if I look at the pictures of identifing the cams I think its for a "92-01 US & JDM B16" well heres the pictures I got off my motor. Please let me know anything that u folks see that u think might help me. So again thank u in advance. So I now also answered my question of is it a type r head. Of which it is not.
Old May 15, 2013 | 12:35 AM
nate808's Avatar
Ok well sorry cant post pictures yet im not a full member. But if u know of a way I van ill be glad to try. I have the pics saved to my android phone. Thanks
Old May 15, 2013 | 03:41 AM
You have to host the pictures on a website like Flickr or photobucket and then link it from there
Old May 15, 2013 | 10:33 AM
nate808's Avatar
Old May 15, 2013 | 10:46 AM
nate808's Avatar
http:// http://s1286.photobucket.com...pc808/library/
Old May 15, 2013 | 10:47 AM
TypeRfit's Avatar
RESIDENT
Take off the http in your link and it will work.
Old May 15, 2013 | 10:49 AM
nate808's Avatar
http://s1286.photobucket.com/user/natepc808/library/
Old May 15, 2013 | 10:50 AM
TypeRfit's Avatar
RESIDENT
Those appear to be b16 cams
Old May 15, 2013 | 10:52 AM
nate808's Avatar
Ok think I got it now. Let me kno what u think. Year code is 91 so I don't belive type r was out that earlier? But i dunno. Lol
Old May 15, 2013 | 10:53 AM
TypeRfit's Avatar
RESIDENT
Check this out.
https://honda-tech.com/forums/acura-integra-type-r-8/how-identify-itr-camshafts-1220152/
Old May 15, 2013 | 11:03 AM
Those are sir2 cams
p30 intake manifold
sir2 serial number
Looks like a very dirty and neglected, but original sir2
Old May 15, 2013 | 11:08 AM
nate808's Avatar
Yeah those pictures is what I saved to my phone to base it off of wen I took it apart. It looks like the 92-01 b16a cams right the us & jdm cams right?
So now my guestion is the green paint on the dizzy mount. Or is that just somthing someone made up. If Ifind the link I'll let u kno? Thanks for ur help. Also if I wanted to upgrade to either gsr or type r cams could I just drop it in or should I change to aftermarket cam gears. And upgrade my springs? Its not that im trying to race or anything I just wanna unleash a few extra ponies under the hood and occasionally open it up a little. Sorry I kno long post but thanks for ur time .
Old May 15, 2013 | 11:13 AM
Why are you hung up on green paint by the dizzy? From all of your pictures...it is clear that is a sir2 motor
Don't bother upgrading to gsr cams...you will not feel any difference at all.
If you do upgrade to type r cams, use your stock cam gears. No need for aftermarket.
You don't need to change the springs unless you plan on reving over 8500rpm. And if you did, all you would need is another set of intake springs to put on the exhaust side.
