Tranny Issue
So everything is done but hooking up the cable for the tranny. It's a hydro tranny on a 01' GSR motor Into an 00' Hatch. the cable off the tranny isn't long enough to reach the part it needs to go to on the fire wall.
Any help would be appreciated.
sorry, perhaps cable wasn't the best of words. What i need is to somehow connect the rubber hose that is on the tranny, to the hard lines that are on my fire wall. Part of the lines are hard (aluminum or something) and then they have fittings where rubber hoses are also used.
in other words, what do i need to hook up my fluid line with a 01' gsr motor into a 00 hatch so when i push my clutch pedal in.. it works
OH the slave cylinder.
damn you were confusing me lol
you can remove the slave cylinder that came with the GSR tranny (i assume its still attached but the rubber line is cut) then use your stock one.
if you dont have a stock one you can use an open ended wrench and just unscrew the rubber line out of the slave cylinder and swap them.
hteg12
Oct 1, 2013 09:03 PM
Walterronny
May 27, 2006 04:12 PM
jdmCivic925
Sep 23, 2003 10:02 PM
