throttle bracket for skunk2 int. man.
who has a skunk 2 intake manifold and what throttle cable bracket did u use?? because i cant figure out how to mount my throttle cable to the car without the throttle stickin who what kind and were
which engine? i think you need to use the b18c5 bracket to bolt up both holes. i'm using the b18a bracket and i was only able to use one bolt. if your throttle is sticking, you might want to try cleaning out the throttle body around the butterfly...take it off the manifold and clean it with a toothbrush and carb cleaner.
do you have the means to post a pic and be more specific? on my b20 throttle body i actually had to change the butterfly bracket out to make it open right.
boostingisfun
Aug 27, 2007 04:54 PM
SpeedDreamz.com
May 31, 2004 06:37 AM
