swap help please!
Old Aug 26, 2002 | 05:26 PM
Malachi's Avatar
Default swap help please!
alright, got the b18c1 running today. problem is it only runs with an gas rag in the throttlebody. for some reason i dont hear the fuel pump prime up when i turn the key to on. i have 1/4 tank of gas. when i pull the 10mm bolt on top of the fuel filter nothing. what should i check?
also when it was running the tach just stayed at 0, what should i check there? other than that im excited. it sounded real good, especially for still having that gap in the exhaust.
greg
Old Aug 26, 2002 | 06:52 PM
Malachi's Avatar
Default Re: swap help please! (Malachi)
update* i took off the dist and tightened the blue wire. she starts up now, but still no tach. i put a gsr cluster in so im gonna pull it out and see if its wired wrong. im crossing my fingers that i just messed something up in the wiring.
Old Aug 26, 2002 | 06:55 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
good luck with that.. i hope it all works out well.. its a great car once its up and running!
Old Aug 26, 2002 | 06:59 PM
Malachi's Avatar
Default Re: swap help please! (Hatchy-Ownzjo0)
loud as all get-up with that hole in the exhaust
Old Aug 27, 2002 | 03:01 PM
g's integ's Avatar
update me on the ecu...
Old Aug 27, 2002 | 07:05 PM
Malachi's Avatar
Default Re: swap help please! (g's hybrid)
ecu is perfect, thanks a bunch. i just gotta put the axles in now, find where i messed up the wire on the guages. then its to the muffler shop to get a flewpipe welded in!
Old Aug 27, 2002 | 08:17 PM
FrankEXsteiN's Avatar
when i did my swap, my tach in the cluster did not work either. i believe that some wires will have to be moved for it to work. bad news is, i have no idea on how to do that, dont even know why i posted.....
iheartjayDem
11
Jan 28, 2015 06:39 AM
74civic4x4
Aug 25, 2010 12:07 PM
89POS
Oct 2, 2004 01:27 PM
Rhythm Racer
Dec 21, 2003 07:39 PM
