swap help????????????????????????
Im about to get a Cheap .........Automatic 92 hatch. Ive allready have a 2000 b16 wit tranny ecu........etc... what other parts do i need and how much would it cost cluch kit etc.. Would i have to cut or weld anything????
You need the 5-speed pedal ***. clutch master, and slave cylinder, and the hard line. Place racing motor mounts you can't use that ecu you need the obd1 ecu, Do you have the axles ou also need the shift linkageAnd that sould be it, you can just rewire the harness to run the vtec. Have fun.
getupoffthatthan
10
Jul 27, 2007 11:11 PM
Tuesdaynightfever
Apr 3, 2005 12:32 PM
