a supercharged ls in a hatch
Old Mar 9, 2006 | 05:34 AM
superacura06's Avatar
Default a supercharged ls in a hatch
will someone tell me what i need to swap a ls motor in a 92-95 civic i have a whole integra that i wrecked in the rear and i want to put it in a hatchback do i need to buy anything or not the integra is a 94-01
Modified by superacura06 at 8:08 AM 3/14/2006
Old Mar 9, 2006 | 05:36 AM
JibOnALib's Avatar
Default Re: a supercharged ls in a hatch (superacura06)
as long as it is the same obd I don't believe you will need to buy anything, because you have the mounts and shift linkage. anyone feel free to correct me if i'm wrong
Old Mar 9, 2006 | 09:59 AM
MrMike's Avatar
everything u need is in the integra.
Old Mar 10, 2006 | 06:23 PM
eastbay92cx's Avatar
Default Re: a supercharged ls in a hatch (MrMike)
yeah the more you work on your project you'll begin to realize that those two (eg and dc2) are basically the same car (chassis). You have a nice opportunity to make a hybrid (eg chassis, integra drivetrain, brakes, suspension, interior if you like, etc...). At very least, I think you'll need the engine, trans, axles, shift linkage, and ecu, you could leave the wiring harness on the LS engine and plug it into the shock tower on the eg (I think?). anyway, good luck let us know if you have any more questions.
one of the many write-ups on a b swap should take care of you (archives)
edit: I just noticed you didn't specify 94-01 integra. If it is older, you might have to use your existing wire harness or computer (chipped).
almostjdmeg
Oct 27, 2009 08:21 PM
Hellraver
Nov 19, 2007 07:17 AM
prolifik22
10
Aug 23, 2007 10:44 AM
drowzysleeper
Sep 24, 2006 10:40 AM
mycvc8u2
Jan 3, 2003 07:51 PM
