subframe under EG H22
Old Apr 22, 2003 | 08:01 PM
M1kevtec's Avatar
New User
Default subframe under EG H22
will this fit on my car I have an EG with H22a
http://cgi.ebay.com/ebaymotors...&rd=1
Old Apr 22, 2003 | 08:06 PM
poison's Avatar
Default Re: subframe under EG H22 (M1kevtec)
I wish I knew bro. But it doesn't even say what brand it is.
I believe there is only one brand of traction bars that will clear h22 eg's.
Old Apr 22, 2003 | 08:15 PM
Newman's Avatar
New User
Doesn't look like it will. I've seen one of those on a Civic with a B-series motor and it was very close to the motor/oil pan/downpipe. With the H22, it hangs a little bit lower so it may not have enough clearance for that. And if it did, it'd be hanging pretty low to the ground and you'll be scraping it on everything.
Old Apr 23, 2003 | 02:41 AM
wHOAlly's Avatar
Default Re: subframe under EG H22 (Newman)
no way it wil fit, i have a be seires and it basically touches the bottom of my header
Old Apr 23, 2003 | 06:10 AM
EKhothatch's Avatar
I would say probably not. I've only seen one traction bar for an h22 civic. I'm not sure if it was custom or a production model, I'll have to find that out. I'm thinkin he said its was a Moroso. Whatever it was, it was expensive. About a grand.
I asked jimfab.com if his would bolt up. He said probably not cuz of the tranny and the crank pulley. He said he has had alot of requests so hopefully he can produce one soon.
1990accordpnw
Aug 1, 2015 08:58 AM
91' LS-VTEC
Feb 20, 2007 11:33 PM
jdmcivicferio
Nov 25, 2003 08:26 PM
LoudAccord
Aug 9, 2003 05:05 PM
