Static compression ratio question.
Old Oct 5, 2007 | 04:09 PM
slammed_93_hatch's Avatar
Default Static compression ratio question.
I have a question about the static compression ratio for this motor combo. It has been along time since i have messed with B series motors so i am not sure.
B16a block, and crank, with CTR pistons, and a GSR head.
IIRC the gsr combustion chamber is different the b16a and b18c1/5 and i thought it neted more compression...
Thanks for the help
Old Oct 7, 2007 | 03:11 PM
delsol456's Avatar
Default Re: Static compression ratio question. (slammed_93_hatch)
~11.1:1
Old Oct 10, 2007 | 11:53 AM
mik101's Avatar
I'd probably be leary about clearances of those pistons with the head. They'll be out of the hole on the b16a block. And yes the GSR does have a smaller combustion chamber than the B16/ITR head. It'll probably net in the range of an additional 0.2-0.4 compression depending on what combo of parts is used and how far in/out of the hole the pistons are going to be.
Old Oct 10, 2007 | 08:04 PM
Default Re: Static compression ratio question. (mik101)
thanks for the help, i talked to some one super knowledgeable on the subject. And he said it isn't needed and just causes issues using the GSR head.
Any one have a b16a long block for sale?
slammed_93_hatch
Oct 7, 2007 04:51 PM
khang77642
Jun 20, 2003 10:07 AM
McFly
Dec 21, 2002 10:08 PM
