which spark plugs?
Old Jan 14, 2007 | 01:31 AM
baby type r's Avatar
Default which spark plugs?
I did a ls/vtec swap in my eg and for some reason the spark plugs are hitting the pistons. I have the 12:5:1 compression weisco pistons. Does anybody know which spark plugs I can use that are shorter so they don't make contact
Old Jan 14, 2007 | 07:58 PM
Pee Wee's Avatar
Default Re: which spark plugs? (baby type r)
did you use the correct plugs? like if you are using a gsr head, use gsr plugs
Old Jan 14, 2007 | 11:56 PM
Richard...'s Avatar
Default Re: which spark plugs? (Pee Wee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee &raquo;</TD></TR><TR><TD CLASS="quote">did you use the correct plugs? like if you are using a gsr head, use gsr plugs</TD></TR></TABLE> X2
Old Jan 15, 2007 | 01:43 AM
I used the b16 head and got the ones for the b16 but for some reason they are hitting the pistons. Maybe because of the higher compression I am not sure why it is doing it but it is.
Ruy
May 14, 2013 05:43 PM
em1si
Sep 3, 2007 12:23 PM
MenaceL.A.671
Aug 1, 2005 09:32 PM
