Sparadic Idle
Old Sep 19, 2005 | 10:22 AM
Neondog82's Avatar
Default Sparadic Idle
I tried searching but the engine is busy, for the past hour! I will search again when I can. My H22 Civic is constantly idling from about 1 1/2 - 3. Sounds like a vacuum leak. I checked all lines coming off of the intake manifold. The EGR is not hooked up at all and those lines are capped. The IAB is not in use and the line on the intake manifold is capped off. The evap cannister is hooked up partially. Its hooked up to the line closet the intake near where the MAP sensor hooks up. The line going towards the back of the car is hooked up. The third line is not, however I completley disconnected the evap from the intake manifold and still the same problem. All of the vaccum lines are brand new Hose Technique hoses. Does anyone have a clue what the problem could be?
Old Sep 19, 2005 | 10:42 AM
jfboy's Avatar
Default Re: Sparadic Idle (Neondog82)
Could be a bad IACV or maybe even a bad TB
Old Sep 19, 2005 | 11:48 AM
Neondog82's Avatar
Default Re: Sparadic Idle (jfboy)
Could you explain more? could the gasket on the throttle body be bad? Wouldnt I get a MIL code if the IACV were bad? the only codes I have now are for oxygen sensor and ECT. The O2 sensor is not hooked up and the ECU is UK spec (long story) and the engine is Jap spec,...so the engine does not have an extra ECT sensor.
Old Sep 20, 2005 | 08:47 AM
Neondog82's Avatar
bump
jdm_ek_noob
Jan 27, 2014 03:04 AM
90Rexx
Mar 11, 2009 05:59 PM
d_SUPAl1l
Nov 21, 2006 07:39 PM
eg6sir88
Nov 2, 2005 08:53 AM
SUMORex
Mar 24, 2002 05:19 PM
