Some B16B ?'s
I've tried searching and I have not found a true answer to this. I was thinking of putting ITR rods/crank in my B16B. Would that stroke it to 1.8L? Also once the motor was built i was thinking about 84mm sleeves is that safe on a B16B? Hoping for 200-225whp. Or should I just sell the swap and go b20vtec?
you need to search harder, yes that will make it a 1.8, if you going to do all that though why not start with a b18c5? or do a b20vtec with a type r head?
yea...you could sell me that b16b and build a b20vtec if you like.
adding a c5 rods/crank it would be a 1.8L the deck heights of the b16b and b18c are the same. changing to 84mm bore would be a 2L
Deetz
Sep 21, 2004 01:36 PM
