Single long slow flashing engine light????
Old Feb 21, 2004 | 01:01 PM
kholmes's Avatar
Default Single long slow flashing engine light????
What does it mean, o2 or air temp sensor? Or something else?
Old Feb 21, 2004 | 02:00 PM
2trix's Avatar
Default Re: Single long slow flashing engine light???? (kholmes)
just a long would be 10...iat i think?
Old Feb 21, 2004 | 02:04 PM
kholmes's Avatar
Default Re: Single long slow flashing engine light???? (2trix)
Thats what i thought too because I didnt have the air temp sensor plugged into the harness but today I got one and it still does it. I dropped a d16y8 into the hatch and used a auto harness and did what was needed to work the harness on but Im getting this flashing light??
Old Feb 21, 2004 | 03:35 PM
Combustion Contraption's Avatar
i have the same code i also cant get rid of. im thinking the sensor itself is bad.
Old Feb 21, 2004 | 04:02 PM
kholmes's Avatar
Default Re: (LsVtec92Hatch)
The sensors brand new. Hows your car run with it flashing?
Old Feb 22, 2004 | 01:07 AM
ShakesTheKlown's Avatar
Default Re: (kholmes)
Is this when the car is running normally, or when you jump the ECU to get the code?
Old Feb 22, 2004 | 01:09 AM
kholmes's Avatar
Default Re: (ShakesTheKlown)
When I jump the ecu. I havent started it yet cause im waiting on some parts still.
Old Feb 22, 2004 | 04:18 AM
VTECVillain's Avatar
1 long flash is the IAT Intake Air Temp sensor, 1 short flash would be the primary O2. After getting the CEL, make sure to reset the ECU since it could be storing the code even though you already fixed the problem.
Old Feb 22, 2004 | 09:47 AM
kholmes's Avatar
Default Re: Single long slow flashing engine light???? (VTECVillain)
Sweet, no code now. I didnt think about reseting it, thanx alot.
JJexpress
May 5, 2012 06:22 PM
deftones0817
30
Sep 2, 2006 05:21 PM
yellowcrx13
Jan 21, 2004 03:41 PM
Charlie Moua
Jan 13, 2003 08:32 AM
Frosty_spl
11
Jun 20, 2002 05:18 AM
