shift linkage for DELSOL
Old Apr 29, 2004 | 10:05 AM
showtymers619's Avatar
* B A N N E D *
Default shift linkage for DELSOL
im puttin ga b series in my delsol.. can i use integra linkage or do i need to use the DOHC vtec linkage from a delsol?
Old Apr 29, 2004 | 08:20 PM
EK K20's Avatar
Default Re: shift linkage for DELSOL (ShowTymers619)
The integra linkage will not work. Most dealors can get the linkage from the DOHC del sols ( make sure to say DOHC del sol if you say vtec they will prob send you the sohc vtec ones ) and they will bolt right in, the angle is much different then the integras or 99 si. RageDzine on this site has a shop and i know they stock them. Good Luck
Old Apr 30, 2004 | 05:28 AM
Googs16's Avatar
I had a B18 in my delo sol Si . . . you gotta get the del sol vtec shift linkage
Old Apr 30, 2004 | 08:11 AM
VTECVillain's Avatar
Default Re: shift linkage for DELSOL (EK K20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK K20 &raquo;</TD></TR><TR><TD CLASS="quote">The integra linkage will not work. Most dealors can get the linkage from the DOHC del sols ( make sure to say DOHC del sol if you say vtec they will prob send you the sohc vtec ones ) and they will bolt right in, the angle is much different then the integras or 99 si.</TD></TR></TABLE>
This is true. For any B series swap into a Del Sol, you need to get the Del Sol VTEC (B16A) shift linkage.
Old Apr 30, 2004 | 02:46 PM
doublejz's Avatar
Default Re: shift linkage for DELSOL (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
This is true. For any B series swap into a Del Sol, you need to get the Del Sol VTEC (B16A) shift linkage.</TD></TR></TABLE>
Eg2707
Feb 15, 2008 12:12 PM
skiracer8148
Mar 17, 2007 05:09 PM
SOLvtec
Oct 27, 2006 09:30 AM
mintscorpion
Jul 17, 2005 11:26 PM
lovitalracer
Feb 14, 2005 07:49 PM
