screaming alternator
Old Mar 23, 2006 | 08:04 PM
94h22's Avatar
Default screaming alternator
my alternator screams until i rev up the engine then it goes away for awhaile. i hear a bad ground will cause this. where are the engine ground wires. i have a h22 swap in 94 accord. my belt is tight. also i doesnt make any noise if i disconnect the green plug and the 12-volt wire from the alternator. thanks for any help
Old Mar 25, 2006 | 11:41 PM
aspec101's Avatar
Default Re: screaming alternator (94h22)
sounds like you need to tighten your alternator belt. It stops "screaming" when you disconnect your alternator because it is no longer putting a load on your belt.
Old Mar 26, 2006 | 01:10 PM
hapexamendios 2.0's Avatar
R.I.P.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94h22 &raquo;</TD></TR><TR><TD CLASS="quote">my alternator screams until i rev up the engine then it goes away for awhaile. i hear a bad ground will cause this. where are the engine ground wires. i have a h22 swap in 94 accord. my belt is tight. also i doesnt make any noise if i disconnect the green plug and the 12-volt wire from the alternator. thanks for any help</TD></TR></TABLE>sounds like the belt.. like the guy above me said
76 camaro car
Jul 1, 2012 07:52 PM
ge_itr
Dec 2, 2006 04:46 AM
ge_itr
Dec 1, 2006 11:47 AM
2point2
Mar 29, 2005 11:11 AM
mjrage
Jul 4, 2004 01:06 AM
