s2000 swap?
Old Apr 22, 2003 | 09:00 PM
redrum92si's Avatar
Default s2000 swap?
If the s2000 engine is a F20C and it is possible to swap a F20B swap into a 92-95 civic. Would it be possible to maybe use the F20B tranny on a F20C engine then swap it into a hatch?
Is it possible to put a F20B into a eg or ek chassis? Would a F20B tranny bolt up to the F20C? Don't F series engines and H series engines share something in common? Like trannys or something..?
.....brainstorming
Old Apr 22, 2003 | 09:15 PM
IS3Fifty's Avatar
Default Re: s2000 swap? (redrum92si)
you do realize that this is a rear wheel drive motor right?
Old Apr 22, 2003 | 09:21 PM
redrum92si's Avatar
Default Re: s2000 swap? (TODAeg6)
yeah I know
not only would the tranny have to be changed but the mounts are on the wrong sides
oh well...
Old Apr 23, 2003 | 04:37 AM
length's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">you do realize that this is a rear wheel drive motor right?</TD></TR></TABLE>right this car is a rear wheel drive engine, however my boy just did the swap into an eg hatch. It has the same mount setup as an H22, and all you have to do is use a GSR tranny. Bolts right up. and there fast as balzzz.
do the swap its worth it , to feel third generation Vtec in a hatch is nutz
Old Apr 23, 2003 | 05:04 AM
SleeprCivic's Avatar
Default Re: s2000 swap? (airteck371)
that guy have the car on the net anywhere? I gotta see this...
Old Apr 23, 2003 | 05:23 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airteck371 &raquo;</TD></TR><TR><TD CLASS="quote">right this car is a rear wheel drive engine, however my boy just did the swap into an eg hatch. It has the same mount setup as an H22, and all you have to do is use a GSR tranny. Bolts right up. and there fast as balzzz.
do the swap its worth it , to feel third generation Vtec in a hatch is nutz</TD></TR></TABLE>
First of all, an F20b is a destroked H22. And you can't use a GSR tranny on an H series motor without a custom adapter...which I don't anyone's ever done before?
Secondly, an F20c is NOTHING LIKE the F20b!!!! TWO TOTALLY DIFFERENT MOTORS! They don't even rotate in the same direction! Honda's concept of "interchangeable" engine codes stopped with the new i-VTEC based motors.
God, there's nothing I hate more than noobs giving out FALSE INFORMATION!
Old Apr 23, 2003 | 07:37 AM
redlineh22a's Avatar
Default Re: s2000 swap? (98CTRCoupe)
Just by looking at the dementions, it doesn't look like a swap you want to just tackle with no hesitation. You make it seem like your just droppin it in...
Old Apr 25, 2003 | 12:18 AM
philly-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe &raquo;</TD></TR><TR><TD CLASS="quote">
the flag says it ALL
Old Apr 25, 2003 | 12:23 AM
MikeMAN's Avatar
if you don't at least know they are different engines (completely) shut the **** up
mike
Old Apr 25, 2003 | 12:24 AM
Kamin's Avatar
******* bullshit
show me proof newbie.
if it has the same mount setup as a h22 it goes against EVERY rear wheel drive mounting system ever used. (they are all basically the same)
Old Apr 25, 2003 | 12:31 AM
polycrx's Avatar
Default Re: s2000 swap? (peichie)
im sure he saw it on super street.
Old Apr 25, 2003 | 06:27 AM
BoM's Avatar
BoM
Default Re: s2000 swap? (polycrx)
maybe it was sarcasm.
Old Apr 25, 2003 | 07:15 AM
Scott - 93HB Si's Avatar
ya you could do it using an F or H series tranny....but since the F20C spins opposite direction of the F20b, you'd be going really fast in reverse!
Old Apr 25, 2003 | 08:34 AM
MikeMAN's Avatar
Default Re: s2000 swap? (BoM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoM &raquo;</TD></TR><TR><TD CLASS="quote">maybe it was sarcasm.</TD></TR></TABLE>
maybe it was saracam who knows, im just trying to get the point across how it gets real tiring when a guy with no experience with cars or what we are talking about, chimes in.
Example: Q: "I was wondering how much boost i can run reliably on a stock honda engine?"
A: "I heard you can run around 25-35 psi, just make sure you have a vortec 4:1 fmu with stock injectors, you don't really need an intercooler but it helps, and use a 2.01 a/r turbo for the best results..it will spool by 10 rpms"
Old Apr 25, 2003 | 06:49 PM
Default Re: s2000 swap? (MikeMAN)
You and your "bud" must of had some big miscommunication. Cause that swap IS NOT EASY, and would cost a shyt load.
Old Apr 25, 2003 | 07:02 PM
JSPECEX's Avatar
Default Re: s2000 swap? (Scott - 93HB Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott - 93HB Si &raquo;</TD></TR><TR><TD CLASS="quote">ya you could do it using an F or H series tranny....but since the F20C spins opposite direction of the F20b, you'd be going really fast in reverse!
lol funny **** i saw a car on here that drove backwards some guys in europe made it
Old Apr 25, 2003 | 11:34 PM
MIRRAdekhtc's Avatar
Default Re: s2000 swap? (JSPECEX)
hahaha.....jesus....
all i got to say is " WHY "??
you know speaking of s2000's....now this isn't b.s. Last year, at a car show in Lawton, Oklahoma, there was a little roadster of some kind, i don't know if it was custom built or a kit car or what. It was a one seater, like a miniture hot rod, it was a little car...But we were walking by it just admiring all the cars and when we walked by the little roadster i glanced at it and just kept walking...and then one of my friends was like "hey check this out", this isn't bullshit, and i will find the pics and post them for everyone, i forgot all about it until i read this thread...this little roadster had and s2000 swap in it..i guess i didn't notice it at first, b/c the hood, was split in the middle, it opened on both sides, and the side facing the crowd was closed.
Me and my friends looked at it for about 15 mins., and took a bunch of pics of it so noone would think we were full of ****, and we wanted to talk to the owner but he was gone, we waited for awhile, to ask him about it..Also i don't know if it was a local car, or from another state, but if anyone has seen this chime in..and i will find the pics and post them.
most little hot rods you see at car shows, usually you expect to see a chromed out v8 in them, but i guess someone had alot of money to spend, and wanted to be different, and wanted to be able some performance too...it was obviously rwd, and he had the exhaust ran right out the right under side of the car..didn't get to hear it running, but i can imagine it was loud as hell, especially if he wound it up.
Old Apr 25, 2003 | 11:59 PM
IM ALL BOB's Avatar
Default Re: s2000 swap? (MIRRAdekhtc)
I have no idea what you just said.. and where are the pics of it? probably a kit car.. since there is a company in the U.S that does install F20C/B18C5's/K20's in Lotus "Kit Cars"
Old Apr 26, 2003 | 01:20 AM
Red Rising Sun's Avatar
Default Re: s2000 swap? (IM ALL BOB)
hey, got some questions.
for I am also a little nub in some stuffs.
what's the difference between F20b and F20C, and where is the specific engine used in which car?
Old Apr 26, 2003 | 01:32 AM
IM ALL BOB's Avatar
Default Re: s2000 swap? (Red Rising Sun)
F20B = ACCORD SIR-T engine(not found in North America) .. 2.0motor with 200hp...11.0:1 CR (basically simliar to H22 but with less displacemet.. so it can easily be swapped into civic/prelude/integra/accord
F20C= S2000 engine 2.0motor with 240hp...11.4:1 CR since the drivetrain is based on a RWD vechile it's almost impossible to bolt up to civic/accord/integra/prelude without major modification and money
FreeMyndz v.FP
22
May 24, 2013 06:30 PM
baby type r
Jan 23, 2007 05:54 PM
delsol101
Jan 9, 2006 03:18 PM
s2kmonkey
Honda S2000
14
Sep 17, 2005 09:05 PM
LilManSi
22
Sep 5, 2004 08:51 PM
