Rewiring CKF
Old Oct 5, 2002 | 10:57 AM
madtownhonda's Avatar
Default Rewiring CKF
I cut the CKF plug off my 96 d16y8 engine and wired it onto my 99 b16a2, but the damned CKF is still not doing anything. Blue to blue, white to white, and I left the ground open. Still getting DTC 54
what's the problem
EDIT: I'm using an OBD2 P30 96-7 Del Sol Vtec ECU
[Modified by madtownhonda, 7:58 PM 10/5/2002]
Old Nov 28, 2003 | 01:17 PM
stehigs321's Avatar
Default Re: Rewiring CKF (madtownhonda)
I have the same problem, what can we do??
Old Nov 28, 2003 | 06:33 PM
Fobtions's Avatar
Default Re: Rewiring CKF (stehigs321)
obd2 ecu's need to be cleared out using a obd scanner.
Old Nov 29, 2003 | 08:43 AM
holy old post!
anyways...just pull the fuse for the ecu in the underhood fuse box for 30 seconds and it will go away provided you wired it correctly.
Old Nov 29, 2003 | 11:11 AM
stehigs321's Avatar
I dont know if i wired it correctly. What color are the wires that go to the CKF sensor on an engine harness for a 96 civic EX?? I have 3 wires and one i dont use. WHat are the wire colors so i can find them. then make sure i wire them.
Old Nov 30, 2003 | 05:35 AM
stehigs321's Avatar
Any help?
Old Dec 1, 2003 | 11:08 AM
They should be blue, white, and black. Just match them up and tape off the black one.
b18coupin
Jun 21, 2012 04:51 PM
dstah
May 4, 2009 04:57 PM
blakkvtec
Oct 6, 2008 04:51 PM
fastfu
May 15, 2008 03:09 PM
ruthless013
Jan 26, 2004 01:31 PM
