Really could use some help!!!!!!!!!!!!!!!!!!!
Old Sep 13, 2001 | 02:26 PM
ChicoT's Avatar
New User
Default Really could use some help!!!!!!!!!!!!!!!!!!!
My original post..........
I am re-doing the head gasket on my ls/vtec this friday and need a game plan, right now I am using a ls head gasket and the car was fine for about 3 weeks then it started to puff white smoke like a forest fire, I have to replace it because its just embarrasing to drive right now, I moved the dowel pins in the B16 head and removed the 2 little copper rings on the LS head gasket...I've heard that when I re-do this I should use copper spray and also that I should move the dowel pins back to their stock locations in the b16 head and bore out the holes in the block so that when the dowel pins are in their stock locations they will fit into the block, and by doing it this way I would be able to use the B16 head gasket...anyone know about this or had experience, any suggestions would be appreciated...
I know that someone knows about LS/VTEC, I really could use some help on this one, we have to re-do this tomorrow and want to make sure I do it the best way possible....thanks
Old Sep 15, 2001 | 06:53 AM
Jared's Avatar
Default Re: Really could use some help!!!!!!!!!!!!!!!!!!! (ChicoT)
Don't use the B16 gasket. You're dowel location shouldnt matter. and the most likely reason for your problem is the removal of those copper rings. you should have left them.
titi_vtec
Dec 31, 2010 05:30 AM
h22civicek
Aug 31, 2008 05:05 PM
Jtuned DC2
20
Oct 1, 2007 06:05 PM
migo
Sep 27, 2002 06:38 PM
